First cut at RPM calculation algorithm
A project log for Adding BLE to a "dumb" treadmill
I have a Gold Gym 410 which is perfect for my purposes. But I always had an itch about tapping into speed and inclination data.
enzo-lombardiEnzo Lombardi • 08/05/2022 at 16:46•0 Comments
So the Reed Switch worked as expected, no brainer of course.
I put together some code to compute the RPMs and display them on the Seeeduino Extender OLED display. If I display the result in RPMs, the output seems to be reasonably right, but if I divide further the fluctuation is bigger. Time to debug.
Current code is here, I am suspecting something is wrong with the 5ms forced delay in the IRQ.
