I started with a 5" 720P touchscreen I found from the same AliExpress seller as the current 3.5" one.
For some reason, the bezels seem too slim, which is a nice problem to have. I also had the below idea to make Timespy look more slender than it actually is:
I had some worries that 121mm was just going to be too long, and I also liked the idea of a 90Hz OLED.
I decided to try angling this side face, which was an idea from TestCut.
Next, I added the Tetrinsics, this time giving Finger 2, 4 and 5 a bit of an angle instead of parallel with the top face. I also added a coloured section to the bezel, which I think finally brings the design into "fresh look" territory. The look was the reason I got my current white smartwatch in the first place.
