Attempt2 Print
I'm going to save my Yousu Galaxy Blue for end-use prints since it's one of the few fancy colours I still have in stock and I don't really want to buy more filament because I want to eventually switch over to TeamResin with the #SecSavr Suspense [gd0105].
It was all excited when the bottom strap loop actually worked, but I didn't have enough clearances for the top strap so it never clicked in, unfortunately. I've now made sure that there's a 2mm offset clearance from the 1.5mm pinhole (so 2.75mm clearance total).
Having Fingers 2-4 on the same level is perfectly fine, surprisingly. Finger5 is still what's failing the solution.
Attempt3 Model
Attempt3 Print
Finger5 still fails. On the plus side, the strap succeeds!
- The strap needs to be more centred.
- The design only needs a bit of persuasion to get through the end part of a sleeve. After that, it can slide though the main length without impedement.
- The cuboid design looks fine on my arm. Larger than a watch? Absolutely, but since the sleeve neatly slides under it, it's seems to blend in. (White gloves would take up about the same visual area.)
- That steep angle needs to go.
- It doesn't seem that my skin had trouble breathing. I'll stick to 20mm bands though, since the band is the main thing touching my wrist.
