Whilst using Attempt4 for a bit, I noticed that Finger5 might be able to slide across the same surface as the other fingers. Theoretically, the finger responsible for [space] and other things would only have to move +/- 2mm for most typing, and printed concepts of the #Tetent TestCut have shown that the thumb could comfortably move well enough to share the same layout as Fingers 2-4. The same can't really be said for Finger5 at the moment, and the reason why I want to try and get a solution that includes Finger5.
In other news, it's quite nice to go all the way back to the first Timespy project log and read that I partially started the project because of the 90Hz screen I found, reject it and then accept it months later because of a design aesthetic change.
