Surgery Success!
01/16/2023 at 17:47 • 0 commentsOtter had his surgery to close the hole in his skull in Dec 2022; his recovery went extremely well and has been back to being an incredible kitten - he'll have the opportunity to grow up to be a healthy loving creature!
Cap Version 2.0 - wire Ear Loops
09/23/2022 at 20:49 • 0 commentsThis is a jig for the laser cutter.
The ends are soldered together. the Wire is 12 inches long
Otter is a beast
09/23/2022 at 20:44 • 0 commentsI've been thinking about doing version 2.0...
Working with the Cupcake Holders
09/09/2022 at 00:50 • 0 commentsAs it turns out, ordering some 3" (actuallly 3.17") diameter cupcake holders worked out really well! They were inexpensive, quick, and easy to cut. Also, There was a decision to add venting holes for Otter's condition. Cutting it from the button to top seemed to prodcue the best results.
The edges need to be cleaned up a bit... it seemed the the bulb tip actually worked better than the razor blade tip... E6000 glue works incredibly quickly when setting the two materials together...
Utilizing a safety Quick Release Clip
08/25/2022 at 23:46 • 0 commentsWe wanted to utilize a Quick Release Cat Collar clip into the design... ultimately I ended up purchasing some quick release collars, cannibalized the clips and went with a simple loop with the velcro straps... To remove the clips I used a razor blade attachment on the wood burning tool (I got the blade tip from Michaels)
Failed Computer Concepts
08/25/2022 at 23:41 • 0 commentsHere are some pics of Digital iterations of Helmet Ideas:
Failed Iterations
08/13/2022 at 00:11 • 0 comments -
Velco Chin Strap
08/13/2022 at 00:07 • 0 comments -
Plastic Shell Styles
08/13/2022 at 00:04 • 0 comments -
Neoprene vs Craft Foam
08/13/2022 at 00:01 • 0 comments
