Buoyancy Engine Prototype 1 (22/08/22)
A project log for Micro Marlin Glider
Small buoyancy engine powered underwater glider designed to travel autonomously.
midnightseabedmidnightseabed 08/22/2022 at 21:530 Comments
The first version of Micro Marlin's buoyancy engine will contain a single syringe with an embedded motor. This is based on a number of previous designs such as the rumblefishrobotics design.
The embedded motor with the long screw thread will pull the plunger/seal back and forth  when 5V are applied (5V works fine). This will allow the intake and expulsion of water which will change the density and therefore the buoyancy of the glider; pull water into the syringe, the buoyancy decreases and the glider will start to sink, push water out and it will instead start to float up.
Components
3D Parts
Issues /Jobs
