Simple design just holds everything together solidly against the fabric.
![](http://cdn.hackaday.io/images/330071662399684363.jpg)
Set on the right can accommodate up to 3; currently configured to hold 2 and a bolt in the empty spot to help hold it together.
![](http://cdn.hackaday.io/images/1930141662399760230.jpg)
Setup on the left can accommodate 4, currently holding 2, a bolt in an empty spot and a little led indicator hooked up to a USB spot on the pc so I'll know when everything is on. Kinda hacky but that's ok for now.
![](http://cdn.hackaday.io/images/1648481662399845929.jpg)
Left set is for the 5ghz pineapple add on. Right set is for alfa dongle attached to the pi.
![](http://cdn.hackaday.io/images/9478441662399939627.jpg)
