Starting to clean up the wiring. This is the transfer area between hardware and power supplies. Also home of small wifi dongles.
![](http://cdn.hackaday.io/images/8485761662586195106.jpg)
This is the home of the power supplies. Gets hot so need fans. Also the space where the oculus rests during transport.
![](http://cdn.hackaday.io/images/7478221662586282568.jpg)
