Auto-sleep in HW rev 0.3
A project log for Canique Switch - nano power relay board
Canique Switch has a 60W latching relay onboard. The board consumes only 35nA when not switching.
caniquecanique 04/16/2023 at 12:380 Comments
In HW revision 0.3 the sleep pin is without function.
Instead there is an auto-sleep circuit onboard, that will make the board sleep when not actively driving SET or RST high.
To switch the relay on, it is enough to only drive the SET pin high for 10ms (while RST is in high impedance or driven low).
To switch the relay off, it is enough to only drive the RST pin high for 10ms (while SET is in high impedance or driven low).
