WiCAN is a powerful ESP32-C3-based CAN adapter for car hacking and general CAN-bus development. It is available in two form factors, OBD-II and standard USB-CAN. The original firmware can use Wi-Fi or BLE to interface directly with RealDash, which allows you to create your own custom dashboards with stunning graphics. It is available for Android, iOS, and Windows 10. WiCAN connects to your existing Wi-Fi network and any device on that network, where it allows you to configure Wi-Fi and CAN settings through a built-in web interface. Both versions have a power-saving mode that detects when the voltage drops under 13 V or some other preset value. When this power-saving mode is engaged, WiCAN is capable of entering sleep mode, which drops current consumption below 1 mA.
