Location, Motion, and Orientation
A project log for Mini-Deck
A Mini Modular Folding Cyberdeck
smeefSmeef 07/25/2023 at 12:200 Comments
Added a PA1010D GPS module and a BNO085 9-DOF sensor on right side. Had to rewire all the I2C devices to allow the wires to get where they needed to go. Also 3D printed a redesigned mounting bracket around the primary display with additional mounting points on the right side, and a 1mm increase in height to allow the secondary display to flip down parallel with the primary display.
