Testing of the actual ASIC
A project log for Zinnia (MCPU5)
8 Bit CPU implemented in 100x100µm² IC area for TinyTapeout
timTim 02/21/2024 at 21:340 Comments
I finally received the TinyTapeout board with the Zinnia+ MCU design!
I decided to use an RP2040 the exercise the I/O of the design. Since the code memory is external to the MCU, it needs to be emulated by a program on the RP2040.
Here is the output of the prime number generation program:
ExampleMore documentation and code here: https://github.com/cpldcpu/tt02-mcpu5plus/tree/main/validation
