I had several challenges now. One of which is that the wires from the Lulzbot Taz 5 box were too short to wire to the new SKR board. Another is that the RAMBo board used a different connector than the SKR. Lastly is that I didn't want to re-pin the entire connector.
The answer is to make extension/adapter leads to go from the Lulzbot connectors to the SKR connects AND lengthen the wires.
![](https://cdn.hackaday.io/images/8849291664055303599.jpg)
Stepper extenders, End Stop Extenders, Temperature sensor extenders. Using some headers as Male to Male adapters I was able to connect everything up nice and neat. Everything should fit where I expect and I am able to test each connection.
