Jog wheel board
A project log for Repurposing an Accom Axial Control Panel
Turning an obsolete video editor console into a mothership-sized keyboard + trackball + stream deck
noughtnautnoughtnaut 09/12/2022 at 08:280 Comments
# Jog wheel board
This board holds 24 keys and 5 LEDs.
Jog board, front
Jog board, front
Jog board, back
Jog board, back
Key switch pin-out
Key switch pin-out
The keys on this board are far from as orderly laid out as on the function board, so mapping them is also rather more messy.
Arbitrarily numbering things:
Surprise: this board uses the same demultiplexer select lines (23, 25, and 27) as the function board. Perhaps other G1/G2 settings, then? Yes: G1 is pulled high and G2B is pulled low as above, but G2A is routed to its own ribbon line  (19), and should be pulled low when scanning.
As before, pin 1 on the key switches are run directly to the ribbon cable, and pin 2 on the key switches are run through a demultiplexer. Also as before, the demultiplier outputs and the return lines are active LOW, so all except the signalled line(s) will be set HIGH.
Demultiplexer
Pin
In
Out
1
Select A
2
Select B
3
Select C
4
G2A
5
G2B hardwired to GND
6
G1 hardwired to 5V
7
unused
8
GND
9
unused
10
unused
11
unused
12
unused
13
[REC/SRC], [MARK OUT], [JOG], [VAR], [SHUTL], [PLAY], [ABSLT], [SWR FADER]
14
[END], [SELECT], [NEXT PG], [STOP], [MARK IN] [VFD 1], [VFD 3], [VFD 5]
15
[START], [PREV], [NEXT], [PREV PG], [USER], [VFD 2], [VFD 4], [VFD 6]
16
5V
So it would seem that, to scan this board, I need to run a binary sequence 0-2 through ribbon lines 23, 25, and 27 to power the jog board keys (pin 2) as follows:
int
bin
r27
r25
r23
IC pin
output (to key switches pin 2)
0
000
L
L
L
Y0, pin 15
1
001
L
L
H
Y1, pin 14
2
010
L
H
L
Y2, pin 13
3
011
L
H
H
Y3, pin 12
unused
4
100
H
L
L
Y4, pin 11
unused
5
101
H
L
H
Y5, pin 10
unused
6
110
H
H
L
Y6, pin 9
unused
7
111
H
H
H
Y7, pin 7
unused
Any pressed key switches (pin 1) should then be signalled on (odd-numbered) ribbon lines 1-15:
key switches pin 2 output
ribbon line
[PREV], [MARK IN], [REC/SRC]
1
[START], [END], [MARK OUT]
3
[SELECT], [NEXT], [PLAY]
5
[PREV PG], [NEXT PG], [JOG]
7
[VFD 1], [VFD 2], [VAR]
9
[VFD 3], [VFD 4], [SHUTL]
11
[VFD 5], [VFD 6], [ABSLT]
13
[USER], [STOP], [SWR FADER]
15
Additionally, 5 of the keys have LEDs; these are all supplied with the same 5V from ribbon line 6/8/10 and individually lighted by pulling pin 3 down via separate ribbon lines.
So in short, here is my new knowledge about the ribbon cable:
Ribbon line
Source
Signal
1
Jog board
2
Main board
GND for [VAR] LED
3
Jog board
4
Main board
GND for [JOG] LED
5
Jog board
7
Jog board
9
Jog board
11
Jog board
13
Jog board
15
Jog board
19
Main board
Jog board G2A
29
Main board
GND for [SWR FADER] LED
31
Main board
GND for [ABSLT] LED
33
Main board
GND for [SHUTL] LED
