Hackaday.io Hackaday.io
Sign up Log in
Pi-Tac
Raspberry Pi Zero W Housed Inside a Tic-Tac Box
smeefSmeef
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.3k views
0 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 14
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
Public Chat
1.3k
0
13
12
Team (1)
  • smeefSmeef
Join this project's team
  • Wordpress site with detailed build instructions
  • Hackaday article with old version
hardware
ongoing project
raspberry pi pi zero tic-tac spy cam
This project was created on 09/12/2022 and last updated 4 years ago.
Description
A Raspberry Pi Zero and camera housed inside a Tic-Tac box. It includes a 500 MAh LiPo battery, a 128x32 OLED connected via I2C, a camera, a USB type-A port, and a Powerboost 1000C with soldered components allowing for startup and safe shutdown via two tac buttons mounted on top. It also does simultaneous access point and client mode so that it can connect to a WiFi network and share the internet connection to other devices connected to its access point. The camera's video stream can be viewed via HTTP to any connected devices. There are also ports under the lid that can connect to a TV.
Components
  • 1 × Raspberry Pi Zero W
  • 1 × Tic-Tac Box
  • 1 × 500 MAh LiPo Battery
  • 1 × Powerboost 1000C
  • 1 × 128x32 I2C OLED
View all 14 components
Build Instructions
Collapse
  • 1
    Build instructions can be found here:
    https://deathonater.wordpress.com/2017/11/04/pi-tac-2-0/
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Raspberry Pi Web Server Cluster running Raspbian-Linux, Apache, MariaDB and PHP.
Project Owner Contributor
LAMPi
developtheweb@DevelopTheWeb
Let Raspberry PI turn into a security cam that you can watch live and control from your mobile
Butterfly PI - Maker Version of a Security Cam
ahmet-ouz-mermerkayaAhmet Oğuz Mermerkaya
Skeleton head turns to face people w/ Raspberry Pi & OpenCV
Skellington Watches You
scottScott
A fully customizable 3D printed camera that takes short gifs using a Raspberry Pi Zero and Raspberry Pi Camera.
PIX-E Gif Camera
nickrbrewernick.r.brewer
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Pi-Tac", please tell us the reason.
Send message
Remove Member
