An 8318 motor attached to a moteus 4.11 (mjbots not affiliated with this project) by a PC-Max bracket. The bracket is printed on a garolite bed with a gluestick and enclosure for no warping or lifting. The power wires are 16 ga soldered to banana connectors to the drone power wires. The magnet was installed by first drilling a hole in the stationary motor bolt, then supergluing the hall effect magnet into the groove.
