First test run needs a case
A project log for Raspberry Pi Pico CNC Shield xSB
I do have the vision, of a cheap CNC Board. Whose creation does not require more equipment and skills as a hobbyist would have.
dd-y41613DD-Y41613 10/09/2022 at 17:381 Comment
I do have published the 3D Model, for the case of the Single Side Board (SSB) version, on Raspberry Pi Pico CNC Shield SSB + Case + 80mm fan by DD-Y_41613 - Thingiverse . I have published it there to honor the two members, whose work I took and adjusted to my needs.
DD-Y41613 wrote 10/09/2022 at 17:41 point
Ups ... I forgot to mention, the first CNC job was successful.
