This project is about building a simple D+ simulator. It´s tracking the voltage of the camper`s starter battery and gives the charge signal to the charge booster which is needed to charge the second battery of the camper. The main part of this project is a Digispark-controller and a relay which shortens the D+ contact to 12V, if the charge booster is allowed to charge. Simple, cheap and easy!
