BES components
A project log for LoRa darkStar
Low Quiescent Current, Solar Powered +30dB LoRa
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 10/23/2022 at 10:520 Comments
Push-fit Tank Connector - 40mm White Part number: 11121 £2.16 1 £2.16
Push-fit Straight Coupling - 40mm White Part number: 11098 £1.43 1 £1.43
Push-fit Screwed Access Plug - 40mm White Part number: 11125 £2.70 1 £2.70
