Much time. Very spend.
A project log for Modular OTS Cyberdeck Creation Kit
A suite of printables designed around using (mostly) off-the-shell parts to make your own custom computing platform/ Cyber Deck/ Lapdock
sp4mSp4m 02/13/2023 at 17:180 Comments
I've been trying to push forward with the next prototype, but there is always a lot to do with the design of a new part.
This is a single module that contains the Deck Dock, a new backup battery that is also a travel charger, a 4 port USB hub, an NVME drive, and a little extra space for a keyboard passthru port and cable manglement.
There are several dumb things I am doing that make this prototype a new challenge.
Obviously the charger needs to be removable, so I'm building it into a drawer that will allow me to socket it into a fixed plug, or pull it out. The drawer even has room for cable storage, which is something this has sorely needed.
Wow, that's awfully dense, and I haven't figured out the cable management for the deck dock yet, but everything else is running through the curve at the front of the chassis. Yay! no wasted space.
