Grabby Little Hands
A project log for Modular OTS Cyberdeck Creation Kit
A suite of printables designed around using (mostly) off-the-shell parts to make your own custom computing platform/ Cyber Deck/ Lapdock
sp4mSp4m 06/14/2023 at 21:560 Comments
The Cyberdock is designed around the Steam Deck, but I want to make sure it's compatible with other common computing devices as well, so I've added some adjustable grips large enough for an ipad pro. An additional benefit is that this can be used to support a tablet device with a very nice screen, and use Steam Link to wirelessly (boo) connect to the deck. Under the right circumstances, it could give you a nicer lookling, larger screen for your gaming pleasure.
I am making significant use of heat-set inserts, and thumb screws.
