1st prototype
A project log for Conway's Game of Life on ATtiny84
ATtiny84-based gamed of life on 8x8 LED matrix with manual setup of 1st generation.
Jean-François PoilpretJean-François Poilpret 12/04/2016 at 11:140 Comments
Project has started on November 26th.
So far I have a running prototype (Arduino UNO for the moment) where initial board setup is done though simple buttons.
Next steps are to replace some buttons with pots, to make it easier to select a LED in the matrix, hence make initial board setup step faster. The challenge here will be to check the code size will still fit in 1KB.
In addition, I am just starting to design a simple stripboard for the whole circuit (except battery holder).
