Animated circut
A project log for Not-so-smart capacitive discharge spot welder
Portable spot welder that doesn't need microcontrollers, uses recycled industrial thyristor and mostly off-the-shelf components
adalbertadalbert 10/06/2022 at 20:530 Comments
I created an interactive animation of a simplified version of the circuit using https://www.falstad.com/circuit/ website.  It shouldn't be treated as an accurate simulation, but it shows the general idea about how the welding pulse is triggered and how capacitor charging and discharging happens.
You can open the circuit in your browser by following this link: https://www.falstad.com/circuit/circuitjs.html?ctz=CQAgj...
Step-up converter module is ommited here.
