OM12 Updated: Replaced Clevis Pins with Foam!
A project log for Open Muscle Finger Tracking Sensor
Forearm Muscle-Based Finger Tracking Device
turfptaxTURFPTAx 03/14/2023 at 18:040 Comments
I recently replaced all of the springs and clevis pins with a foam solution that produces similar results. A lot of the force goes into the elastic band and the depth of the ADCs is very important. With the ESP32-S2 I am able to obtain 1200 samples per second across all sensors or 100 samples per second for each sensor.
The resulting signals are not as 'loud' as I wished them to be but they are reading the movement of the muscles underneath the skin. Will be posting a video update with the pros/cons of this system for use in biometric muscle contraction detection of forearm muscles.
