Part-DB 1.11.0 - LCSC info provider, improved search and API
A project log for Part-DB - Open Source inventory software
Part-DB is an Open-Source inventory management system for your electronic components. It is installed on a web server and so can be accessed
jan-bJan B. 03/06/2024 at 11:500 Comments
LCSC info provider
Part-DB now can use import part information from LCSC distributor. See documentation on how to use it.
Improved search bar
The search bar now makes suggestions for parts while typing. This should make searching much quicker in many cases.
API improvements
It is now possible to properly create new attachments and parameters on elements using the API like you would expect.
Also, it is now possible to upload files to attachments via API and let Part-DB download URLs. See API docs for more info.
Full changelog
https://github.com/Part-DB/Part-DB-server/releases/tag/v1.11.1
