Following assembler directives are used:
structural directives:
these directives determine the context for code that comes after them
.const -- optional block containing list of labeled constants -- primarily these are absolute addresses of memory mapped I/O ports
.text -- indicates start of proper code block, containing instruction sequence
.data -- indication of start of block containing static variables
comment directive
Anything starting with hash symbol (#) and ending with newline is considered a comment and is ignored.
Example: # this whole line is comment LDi r0 0x01 #comment: this operation adds 1 to value in register r0
assignment directive:
= -- used as assignment statement in constants block
Example: .const #start of constants block constant_value = 0x1234
size directives:
these are used only in data segment
.string -- byte-sized array, containing ascii symbols, the value assigned to it is in quotes. At the end of string there is at least one byte with zero value (0x00, C-like string)
.word -- 16-bit numeric value
.dword -- 32-bit numeric value
.long -- 64-bit numeric value
Example: var_1: .word 0x1234 var_2: .dword 0x1234678 var_3: .long 0x1234567890123456 var_4: .string "example string, with \"quotes\" inside"
All parts should be on the same string.
