Directives
A project log for Assembly Language for ECM-16/TTL homebrew CPU
Sub-project where the assembly language is described; the assembler program progress updates are posted here
pavelPavel 11/24/2022 at 10:080 Comments
Following assembler directives are used:
structural directives:
these directives determine the context for code that comes after them
.const  -- optional block containing list of labeled constants -- primarily these are absolute addresses of memory mapped I/O ports
.text  -- indicates start of proper code block, containing instruction sequence
.data -- indication of start of block containing static variables
comment directive
Anything starting with hash symbol (#) and ending with newline is considered a comment and is ignored.
Example:
# this whole line is comment
    LDi r0 0x01   #comment: this operation adds 1 to value in register r0
assignment directive:
=  -- used as assignment statement in constants block
Example:
.const       #start of constants block
   constant_value = 0x1234
size directives:
these are used only in data segment
.string -- byte-sized array, containing ascii symbols, the value assigned to it is in quotes. At the end of string there is at least one byte with zero value (0x00, C-like string)
.word -- 16-bit numeric value
.dword -- 32-bit numeric value
.long -- 64-bit numeric value
Example:
var_1:  .word     0x1234
var_2:  .dword    0x1234678
var_3:  .long     0x1234567890123456
var_4:  .string   "example string, with \"quotes\" inside"
 All parts should be on the same string.
