Current consumption
A project log for Squeak: GPS pet tracker
Squeak is a LoRaWAN GPS pet tracker with a very long battery life. It allows you to ask your pets to share their location
mihaicuciucmihai.cuciuc 11/16/2022 at 06:460 Comments
Adding up the maximum currents for the components for each state I got:
On measurement things improve a little:
Using a 400mAh battery, keeping the GPS off and sending one uplink every 15 minutes should give ~130 days of battery life on 80% of the battery charge.
