Case design with internal antenna
A project log for Squeak: GPS pet tracker
Squeak is a LoRaWAN GPS pet tracker with a very long battery life. It allows you to ask your pets to share their location
mihaicuciucmihai.cuciuc 11/20/2022 at 08:190 Comments
As this is supposed to spend most of its time on a pet's collar, I tried a different case design that's flatter and longer. The goal is to get something smaller than the Tractive. So far no effort has been put into details like actually attaching it to a collar or a charging port.
Size is: 76mm x 29mm x 17mm, 34g. That's 3" x 1.2" x 0.7", 1.2 oz
Tractive is 71mm x 28mm x 17mm, 35g. That's 2.8" x 1.1" x 0.7", ~1.2 oz
