Backlog: 1
A project log for Codename: Project Plapple
Simple project, creating a replacement pcb for the Apple Keyboard II
bulbulBulbul 11/15/2022 at 00:500 Comments
Most of these will be backlogs, I'm trying to muster up strength to write out these old backlogs and give the project a more flushed out context.
For a good view into the apple keyboard II check out this desk authority wiki listing:
https://deskthority.net/wiki/Apple_Keyboard_II
There were 2 manufactures of this keyboard, smk and mitsumi. The cases have small differences and from my very small sample it looks like the smk ones were of a little higher quality.
The internals of both include:
My first attempt at building the board i wanted to mimic the separate controller and keyboard matrix, with the idea that you could make the controller modular and reuse the same matrix.
A breakdown of revision 1 as follows:
Below you can see revision one pictured:
Breadboard version:
Made a protoboard controller:
assembled:
It was functional! however the case fit wasn't perfect and even after breaking off the plastic the case wore down on those 1.27mm connecting cables. I Should note this proto comes long before my confidence in SMD soldering took place hence using available through hole parts. Theoretically would make it easier to hand solder everything and make an easier diy project but I was on the fence about the practicality of it.
Also to note you can assume that in-between revisions there's a kinda constant tweaking and remeasuring so i could get the case fit better, some compromises were also made when designing controller boards to make them fit in both styles of cases vs one.
I'd consider revision 1 a clunky diy quasi success but it was nowhere near as clean as I wanted it which leads to r.2 which I'll cover in the next backlog
