Bridge run
A project log for Smart leash
Simple navigation for pet robots
lion-mclionheadlion mclionhead 07/17/2023 at 21:020 Comments
A very daring exercise to be sure.   Oscillation proved unavoidable but bearable. Noted the leash vibrating & wondered if aliases of the vibration could be oscillating the steering, but it's accepted that stiction of the pot is the reason. The locked down stability of the stick controller is quite conspicuous. It only got that stable after installing a more rigid steering plate & tightening the servo saver.
