![](https://cdn.hackaday.io/images/3574381691349986466.jpg)
The temperature dropped down to 105F this weekend, so I braved the garage and managed to get all the parts of my drawers cut down to there final size. It is getting very hot again and I think I'm done for this weekend. I still need to do a dry fit of the parts to make sure I did not mess anything up, then do a rough sanding to take care of any small oopsies when cutting, then glue and staple them together and finally toss in a few screws to make it really hold together well. Finally the big event, putting them in and adding faces. I went out today and picked up the rest of the materials I will need to finish it all up. So hopefully, if the weather holds, I can get close to finished next weekend. If not, then chances are we will have another month of scorching heat and this could take a while to finish.
![](https://cdn.hackaday.io/images/8061311691350011259.jpg)
