How to make MQTT web app using HTML and Javascript
In this tutorial we will make MQTT web application or MQTT web dashboard using HTML, CSS and Java Script using the Paho mqtt library.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In this tutorial, we will be learning how to make MQTT web application or MQTT web dashboard using HTML, CSS and Javascript. In the previous blogs, I have explained how we can publish and subscribe the data from ESP8266 or raspberry pi using MQTT. You can show that data to web app that we will learn in this tutorial.
source: https://highvoltages.co/iot-internet-of-things/how-to-make-mqtt-web-app-using-html-and-javascript/
youtube: https://youtu.be/rlnhd67PV-M
github: https://github.com/HighVoltages/MQTTwebapp
