SODIMM Bonus
A project log for XiAleste
XiAleste Next is an 8-bit home computer, which is compatible with software for the Amstrad CPC6128 released on 13 June 1985
h2wh2w 12/13/2022 at 13:190 Comments
Using an off-the-shelf SODIM first of all saves development time. But it also gives a certain advantage in terms of the use of printed circuit board area, because components can be installed under the module.
