Three socket connectors, it is not a PCIe interface even though it uses its connector. It is a specialized sound synthesis bus, the details of which will be published when the development is finished. At this point things can still change.
![](https://cdn.hackaday.io/images/902911671187896548.jpg)
A project log for XiAleste
XiAleste Next is an 8-bit home computer, which is compatible with software for the Amstrad CPC6128 released on 13 June 1985
