Instruction Set Shuffle
Having ADD and SUB in different op code pages seems wrong, as SUB (ACC = Value - 1) can be coded as:
- LOAD Value
- XOR F
- ADD 1
- XOR F
Yes, the carry flag works.
The current op code set would be:
- LOAD Value
- PAGE 8
- SUB 1
- PAGE 0
No saving!
To test for a value you could use:
- LOAD Value
- XOR F
- ADD Test
- XOR F
- ADD F
- JNC [Value == Test]
- [Value != Test]
Or:
- LOAD Value
- SUB Test
- ADD F
- [Value != Test]
A better set of op codes would be:
- 0-1 LOAD/LOAD
- 2-3 ADD/SHR using Carry
- 4-5 SUB/XOR
- 6-7 AND/OR
- 8-9 JNC
- A-B STORE
- C-D READ
- E-F PAGE
AND has been promoted over NAND as it can test for bit states:
- LOAD Value
- AND Bit Mask
- ADD F
- JNC [False == 0]
- [True != 0]
Also:
- ADD 0 clear the Carry flag
- SUB 0 sets the Carry flag.
This will be version 5.
Here is the simulation of up counting followed by down counting, then repeat:
![](https://cdn.hackaday.io/images/original/3205241671677366683.gif)
The code for the animation is:
E0 PAGE 0 ; Select Op Code Set 0 20 ADD 0 ; Clear Carry Repeat: 00 LOAD 0 ; Clear ACC Loop1: AF SAVE F ; Output ACC A0 SAVE MEM[0] ; Save to RAM 21 ADD 1 ; Increment 83 JNC 3 ; Loop1 20 ADD 0 ; Clear Carry 0F LOAD F ; Set F Loop2: AF SAVE F ; Output ACC A0 SAVE MEM[0] ; Save to RAM 41 SUB 1 ; Decrement 89 JNC 9 ; Loop2 20 ADD 0 ; Clear Carry 82 JNC 2 ; Repeat
The top level:
![](https://cdn.hackaday.io/images/2764541671775674757.png)
The ALU:
![](https://cdn.hackaday.io/images/1020511671677565507.png)
And control:
![](https://cdn.hackaday.io/images/7425751671775585767.png)
AlanX
