Instruction Set Shuffle
A project log for Hardware Controlled 4 bit CPU
A hardware controlled 4 bit CPU based on lessons learnt from the TD4 and the CHUMP CPUs
agpcooperagp.cooper 12/21/2022 at 13:210 Comments
Having ADD and SUB in different op code pages seems wrong, as SUB (ACC = Value - 1) can be coded as:
Yes, the carry flag works.
The current op code set would be:
No saving!
To test for a value you could use:
Or:
A better set of op codes would be:
AND has been promoted over NAND as it can test for bit states:
Also:
This will be version 5.
Here is the simulation of up counting followed by down counting, then repeat:
The code for the animation is:
E0  PAGE 0           ; Select Op Code Set 0
20  ADD 0            ; Clear Carry
Repeat:
00  LOAD 0           ; Clear ACC
Loop1:
AF  SAVE F           ; Output ACC
A0  SAVE MEM[0]      ; Save to RAM
21  ADD 1            ; Increment
83  JNC 3            ; Loop1
0F  LOAD F           ; Set F
Loop2:
41  SUB 1            ; Decrement
89  JNC 9            ; Loop2
82  JNC 2            ; Repeat
The top level:
The ALU:
And control:
AlanX
