Version 6
A project log for Hardware Controlled 4 bit CPU
A hardware controlled 4 bit CPU based on lessons learnt from the TD4 and the CHUMP CPUs
agpcooperagp.cooper 12/26/2022 at 10:280 Comments
Version 6
Version 6 is like version 5 except the expanded ALU is not used. Here are the op codes:
I wrote up an 8 bit multiplication routine, first in C:
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
unsigned short mul(unsigned char A,unsigned char B)
  // Returns:
  //   A = A * B
  unsigned short res=0;
  unsigned char i=8;  // 8 bit
  LOOP:
    res=res+res;
    if (A>=0x80) {
      res=res+B;
    A=A+A;
    i=i-1;
  if (i>0) goto LOOP;
  return res;
int main(void)
  unsigned char A,B;
  unsigned short M;
  int i,j;
  for (i=0;i<=255;i++) {
    for (j=0;j<=255;j++) {
      A=(unsigned char)i;
      B=(unsigned char)j;
      M=mul(A,B);
      if (i*j!=M) printf("%6d %6d\n",i*j,M);
  return 0;
I tested all cases so I know it works. I then dumbed it down to 4 bits:
unsigned short mult(unsigned char A,unsigned char B)
  // Returns:
  //   C = A * B
  unsigned short C=0;
  unsigned char D=4;  // 4 bit
  LOOP:
    C=(C+C)&0X0F;     // 4 bit adjustment
    if (A>=8) {       // MSB of 4 bit
      C=(C+B)&0X0F;   // 4 bit adjustment
    A=(A+A)&0X0F;     // 4 bit adjustment
    D=(D-1)&0X0F;     // 4 bit adjustment
  if (D>0) goto LOOP; // 4 bit adjustment
  return C;
int main(void)
  unsigned char A,B;
  unsigned short C;
  A=(unsigned char)5;
  B=(unsigned char)3;
  C=mult(A,B);
  printf("C=5*3 %d\n",C);
  return 0;
Although the code handles overflow into the high order bit of the result variable (C), in this implementation, I have not considered overflow of C. Therefore 3x5 is big as the algorithm can handle:
Here is the code running:
In the RAM window: A, B, C & D are updated as the program runs. At the end, the output port displays the answer.
The run starts with:
At the end:
Here is a version that handles lager numbers:
If you used A=13 (D) and B=15 (F), then the result would be C=3 and D=12 (C) or 195.
Refer to the Simulation below:
Unfortunately both of these programs are too big for my 32 byte PROM design.
I will check the schematic tomorrow for any missed errors.
Yeah, found two errors, fixed and forwarded for manufacture.
AlanX
