Let's look under the shield
A project log for Phi Go
A Linux computer on board with extra power and connectivity options
mastro-gippoMastro Gippo 08/20/2014 at 16:090 Comments
So let's see what's under the shield! I had to remove the shield, the SIM and SD connectors with my hot air station:
And here's the PCB in all its glory:
The Mediatek chipset requires a very small amount of passive components to work, so the PCB design is quite simple, as it's just a matter of connecting the chipset to the data bus and take care of the antenna connector coupling. Here's the basic public block diagram for the chipset:
