Hardware
LRAD are Genasys proprietary devices, so there is no access to details and circuits. However, there is a YouTube video where an audio specialist bought one of this devices for study. What did he find? Basically, a speaker horn array with a robust frame, good amplification and specifically designed audios to generate ear discomfort.
In the local market and at reasonable prices I was able to get an outdoor speaker horn and a matching mono amplification board. For detection and audio playback I decided to use a Raspberry Pi, since it has a decent camera, an audio output and easy integration with the Machine Learning platform Edge Impulse.
The complete list of materials is:
LRAD circuit
Connect audio to X segments of the 3.5 jack.
LRAD Enclosure
I’ve found an old PC removable HD tray big enough for all the components of this project. Then I’ve designed a small 3d part to hold 7 segment display and DFRbot Led button.
You can download this part at https://cults3d.com/en/3d-model/gadget/lrad-panel
Machine learning human detection
Lots of people passes by and it would be bad to shock a neighbor walking the dog.
If the sound cannon won’t detect people, could it detect certain actions of the people? Like fights, which actually happens almost every day. The interesting part is that I don’t even need to take hundreds of pictures since there is a dataset with human actions in the AI community Hugging Face.
I wrote a Python script to download 2 actions from this dataset: "people sitting" and "people fighting"
I have created a new project at Edge Impulse platform (free for developers) and  uploaded the pictures, I trained a model and exported to an EIM file.
Audio files
A brave man confronted a police grade LRAD and uploaded the video to YouTube. I downloaded the file, extracted the audio, processed this audio with Audacity app, replicated in time and exported the file as.WAV
Raspberry Pi Configuration
For the Raspberry Pi, I have executed this commands after installing the non desktop version of Raspi OS.
sudo apt-get install python3-pip
sudo apt install git
pip install picamera
sudo apt install python3-opencv
sudo apt-get install libatlas-base-dev libportaudio0 libportaudio2 libportaudiocpp0 portaudio19-dev
git clone https://github.com/edgeimpulse/linux-sdk-python
sudo python3 -m pip install edge_impulse_linux -i https://pypi.python.org/simple
sudo python3 -m pip install numpy
sudo python3 -m pip install pyaudio
I have uploaded the LRAD Python script, WAV file and EIM Machine Learning model (LRAD software)
I have assigned 744 execute permissions to the EIM and added the script to cronjob.
crontab -e
@reboot sudo python /home/pi/lrad4.py > /home/pi/lradlog.txt
Then reboot with sudo reboot
The LRAD script is autoexecuted. In the 7 segment display a greeting will be displayed, then the detection percentage and the trigger notice.
All the console output of the LRAD script are logged into lradlog.txt file
Some code settings to modify:
# EIM file name in case you use a new version
model = "domestic-ml-lrad-2-linux-armv7-v8.eim"
# fighting percentage
detectionLimit=0.75
# GPIO pin for the relay
relayPin=4
# seconds to play the crowd dispersion sound
playSeconds=5
This script is in charge of taking a picture every X seconds and send the picture to the model to get an inference. The model returns a percentage answering the question “is this a fight?” or "there are people sitting?" If the percentage for the first question is high enough, amplification is enabled with the relay and the annoying sound played with a subprocess os call
process = subprocess.Popen("aplay lrad1.wav", shell=True, stdout=subprocess.PIPE, preexec_fn=os.setsid)
TikTok
https://www.tiktok.com/@ronibandini/video/7331372161736805637
Demo and more details
 Final notes
Last but not least, this device is not limited to crowd dispersion. LRADs could also be used to maintain birds out of airports, reject predators in farms, etc
