• 1
    Introduction
    Hey Guys, welcome to my new article. So guys today we are going to make a " Google Assistant Control Car Using Node MCU ".
    Project Information:
    The project is based on the use of AI and IoT devices together for creating a fast, simple and cool ecosystem. Here in this project, I am going to create a Voice assistance control car that makes use of AI (Google assistance, Alexa, etc) and IoT Components (ESP8266, NodeMcu) to make this voice automation car.
    You might be thinking, Where can it be Used?
    It can be used for making a real-world voice-automated car in the future, just like Tesla has their automated parking system in their cars, but to use it we need to use our smartphones to do that, just thinking if you would just say "Hey Google, Park my car" and your car is parked in its parking place. So it can be done by this voice automation idea.
    Special thanks to PCBWay for sponsoring this project.
    So let's get started with the project :-)
  • 2
    Making Of The Chassis :
    ~ So for making the chassis I am using cardboard which is cut 10*14 cm.
    ~ Then we need a gear motor 4pcs.
    ~ We will stick the motor with the cardboard using the hot glue gun.
    ~ We move into the wiring of the motors, the wiring will go in this way we will solder the wires of the same side in a crossword direction. As shown in the above image.
    ~ We will require a rubber wheel (4pcs) for the motor.
    ~ Then our chassis will be ready.
    let's move to the next step...
  • 3
    Attaching The Motor Driver with the chassis:
    ~ over here we will be using the L298N Motor driver.
    ~ Attach the motor drivier to the back side of the chassis with the help of glue. As shown in the image.
    ~ Then you need to connect the motor wire to the motor terminals of the motor driver.
    and that's all you need to do for making the chassis functional.
