Comparison between Bin Files.
I was curious that the blue sherpa program detected that there was a firmware update available but what was the difference?
I happened to take a copy of the firmware before I ran the update using the CM6400 tool so i took another copy using the CM6400 config tool and had a look at the two files.
The only difference between them was the E in the Revision was changed to a 3
R3V8 as opposed to REV8
