Enhanced arcade joystick X4 + Simon says game
An USB joystick system with an integrated credit counter including a Simon says game to obtain credits and enable the insert coin buttons
0 followers
I was a bit disappointed with my first arcade cabinet. Although I employed genuine arcade joysticks and a vintage CRT display you didn’t get the same feeling that playing the original arcades. When playing the original, death was dramatic: if you "died" in the game and you wanted to continue playing you had to spend a valuable coin. In my cabinet you was able to get a credit just by pressing a button so in practical terms you have unlimited lives and the feeling was lost. To solve this I devised a joystick system with an integrated credit counter. The system disables the insert coin buttons unless credits are available and includes a little challenge that must be won in order to obtain them. The challenge is the Simon says electronic game created by Ralph Baer and Howard J. Morrison in 1978. As in the original Simon says game there are several skill levels. The number of credits obtained when the game is won will depend on the selected skill level.
1 Introduction
1.1 Motivation
Thanks to the emulators available nowadays I was able to make my own arcade cabinet. Although I employed genuine arcade joysticks and a vintage CRT display I didn’t get the same feeling that playing the original arcades. When playing the original, death was dramatic: if you "died" in the game and you wanted to continue playing you had to spend a valuable coin. Since emulators let you simulate the insertion of a coin just by pressing a key, in practical terms you have unlimited lives and the feeling is lost. To solve this I devised a joystick system with an integrated credit counter. The system disables the insert coin buttons unless credits are available and includes a little challenge that must be won in order to obtain them.
1.2 The challenge
It is the Simon says electronic game created by Ralph Baer and Howard J. Morrison in 1978. The following description of the game has bee taken from wikipedia (https://en.wikipedia.org/wiki/Simon_%28game%29):
The device has four colored buttons, each producing a particular tone when it is pressed or activated by the device. A round in the game consists of the device lighting up one or more buttons in a random order, after which the player must reproduce that order by pressing the buttons. As the game progresses, the number of buttons to be pressed increases.
1.3 Features
  • Includes four arcade joysticks using just an USB connector.
  • No special drivers are needed.
  • Each joystick has till twelve generic buttons and a backlighted insert coin button.
  • The insert coin buttons are also employed in an integrated Simon says game in order to obtain credits.
  • The insert coin buttons are disabled when there are no credits available.
2 Software configuration
When connecting the system to your computer it will recognize a set of joysticks. No special drivers should be needed. However, if the system is going to be used with arcade emulation software you will need to configure the emulator properly. First you will need to set the first four detected interfaces as the joysticks for the players 1, 2, 3 and 4. The fifth interface is used for interacting with emulators. From now on we will call it control interface. Although the operating system will detect the control interface as 12 buttons joystick, just the buttons in the ranges 1-6 and 9-12 are implemented. Those in the range 9-12 are intended to be used for coin-op game emulators and should be configured as the insert coin button for the player 1, 2, 3 and 4 respectively. The six remaining buttons of the control interface can be configured for tasks such as pausing the emulation, resetting the emulated system, etc.
3 Usage with coin-op game emulators
The joystick set has a counter of credits to be used in coin-op game emulators. The number of available credits is shown in the liquid crystal display. If there are available credits and a coin-op game emulator is running, a player can simulate a coin insertion by following the following instructions:
  1. If a Simon Says game is running (see bellow), wait till it finishes.
  2. Make sure a coin-op game emulator is running. Otherwise you will lose a credit.
  3. Make sure the emulated game support your player number. Otherwise you will lose a credit.
  4. Push the insert coin button of your player.
After this, the credit counter will decrease. In order to increase it you will have to play the Simon Says game embedded in the joystick set by following these steps:
  1. Push the Simon Says start button corresponding to the desired difficult level.
  2. The system will generate sequences of lights and sounds. Reproduce those sequences by pressing the colored insert coin buttons till the liquid crystal display flashes.
The maximum length of the sequence and the number of credits obtained when winning a Simon Says game depend on the selected...
doc.zip
documentation
Zip Archive - 561.65 kB - 01/17/2023 at 19:48
Download
source.zip
source code
Zip Archive - 32.83 kB - 01/17/2023 at 19:47
Download
main.hex
compiled firmware
x-hex - 12.12 kB - 01/17/2023 at 18:55
Download
  • 4 × arcade joystick
  • 48 × generic arcade button
  • 1 × red backlighted arcade button used to simulate coin insertions and to play Simon Says
  • 1 × green backlighted arcade button used to simulate coin insertions and to play Simon Says
  • 1 × blue backlighted arcade button used to simulate coin insertions and to play Simon Says
View all 13 components
  • 1
    Compiling the firmware
    This step is not required unless you want to modify the source code. From a terminal/command line go to the folder/directory containing the source code and execute the following:
    • make clean
    • make all
    This will generate a .hex file containing the compiled firmware. After connecting the teensy board you can program it as shown in the next section or, if you have installed the command line version of the teensy loader application, program it directly by executing this:
    • make program
    You will be requested to push the button of the teensy board. Do so and the firmware will be downloaded.
  • 2
    Programming the Teensy++ 2.0 board
    You can find a detailed description of the following steps at https://www.pj rc.com/teensy/loader.html.
    • Connect the teensy board to your computer.
    • Execute the teensy loader application.
    • Push the button of the teensy board.
    • From the File name, choose "Open HEX File" and open the .hex file containing the firmware to be programmed.
    • Select "Program" from the "Operations" menu, or click the Program button on the tool bar. You should see the "Download Complete" message.
    • Choose "Reboot" from the "Operations" menu, or click the Reboot button on the tool bar.
  • 3
    Building the hardware
    The components must be wired as shown in the following schematic:
    The blue, yellow, green and red backlighted insert coin buttons must be connected to the lines vgnd1, vgnd2, vgnd3 and vgnd4 respectively. The lights of some backlighted buttons can be connected directly to a voltage of 5V like the one generated by the board. Other models may require additional series resistors in order to limit the current through the LEDs. In case of doubt look at its data sheet.
View all 3 instructions
