Enclosure and thermal images
Now it is placed in the enclosure:
![](https://cdn.hackaday.io/images/761381688632665388.jpg)
![](https://cdn.hackaday.io/images/2556171688633588311.jpg)
![](https://cdn.hackaday.io/images/6788871688633640378.jpg)
With the closed enclosure the inverter has been tested at load 250W for temperature rise. Here are some thermal images after 2 hours:
![](https://cdn.hackaday.io/images/6712191688633523581.jpg)
![](https://cdn.hackaday.io/images/6402031688633523595.jpg)
![](https://cdn.hackaday.io/images/4688541688633523589.jpg)
![](https://cdn.hackaday.io/images/5602831688633523586.jpg)
![](https://cdn.hackaday.io/images/7903601688633523603.jpg)
![](https://cdn.hackaday.io/images/6449631688633523596.jpg)
![](https://cdn.hackaday.io/images/6689591688633523596.jpg)
![](https://cdn.hackaday.io/images/8758951688633523578.jpg)
A project log for Battery DC/AC inverter (12V 200VA)
Design of the 12V battery inverter based on a 50Hz iron transformer (square wave).
