The new hardware revision is nearly ready for the production of prototypes!
There were many sleepless nights and now I am approaching the order of the first prototypes.
Module specification:
- A module is a 42x42 mm square PCB with rounded corners
- Modules can be stacked in a rack and racks can be combined with HUB PCBs (more on those in one of our upcoming posts)
- Inter-module connections provide two 2 x 10-pin connectors. The connectors are all-through, with the top connector being female and the bottom connector being male
- The spacing between the pins of each module connector and the pins of the adjacent modules is equal to a multiple of 2.54 mm (100 mils) for compatibility with common breadboards.
And, by the way, the project is now called next.module
