Description and requirements
Fresnel zone antenna
Vector diagram for gain calculation:
Calculation
For 2.45 Ghz
For 5.5GHz
Simulation
Setup
Simulation setup in optiFDTD:
Simulation setup in optiFDTD with plane wave source:
Results – plane incident wave
F=2.45GHz
Result at receiver:
Result along the Z-axis:
Field magnitude along the Z-axis:
Peak position around f=46mm (96mm-50mm):
Conclusion
F=2.45GHz with the presence of a tablet pc or smartphone at the focus
Setup with the presence of a tablet pc at the focus:
Simulation with the presence of a smartphone or tablet pc at the focus:
Conclusion
F=5.9 GHz
Conclusion
Results – simulation with the point source at the far field
Setup
Setup with points source:
F=2.45 Ghz
Comparison at a far distance and point source simulation:
Far-field comparison without and with antenna:
Conclusion
PCB design
PCB design:
Assembly
Two parts connection:
Antenna assembled:
Test results
Setup
Measurement at receiver point:
Measurement results
Measurement at spectrum analyzer:
Conclusion
Notes on practical using
