20230219b -- Actual File Sending
A project log for ROM Disassembly - AlphaSmart Pro
Wherein I disassemble the ROM from a vintage typewriter-thing
ziggurat29ziggurat29 02/22/2023 at 16:190 Comments
Having found the send speed setting, I got a bit interested in the file sending process itself.  Tracing back a reference to "Sending....Press any key to stop. " text, I find sub_F013:
F013             ; XXX prepare to send (flags and prompt)
F013             sub_F013:
F013 FE 01 28        ldx     thisFileRgnFirst_128 ; this file; file region start addr
F016 DF 67           stx     word_67         ; XXX file sending related? ptr to next char to send?
F018 14 6D FF        bset    byte_6D $FF     ; XXX flag? is file sending???
F01B 13 8B 01 05     brclr   byte_8B 1 loc_F024 ; XXX flag?
F01F 14 8C FF        bset    byte_8C $FF     ; XXX flag?
F022 20 03           bra     loc_F027
F024             loc_F024:
F024 14 58 FF        bset    byte_58 $FF     ; XXX flag?
F027             loc_F027:
F027 7F 00 A2        clr     byte_A2         ; XXX flag? cleared in file sending???
F02A BD F7 4E        jsr     setcpLine1_F74E ; set cursor Line 1
F02D CE FE F9        ldx     #aSending____pressAnyKeyToStop_ ; "Sending....Press any key to stop. "
F030 BD F6 69        jsr     showText_F669   ; show nts text @ X
F033 39              rts
This sets up flags in a currently unknown manner prior to presenting the 'sending' prompt.  The most interesting thing I found at this point is word_67 which seemed to be a 'current pointer in file' for the sending process.
F460             ; XXX get next char to send in A; V set if no more chars to send, clear if valid
F460             getNextCharToSend_F460:
F460 DE 67           ldx     word_67         ; XXX file sending related? ptr to next char to send?
F462 BC 01 24        cpx     curfileEnd_124  ; XXX file related (current file ptr end char (one past last)???) .4
F465 27 15           beq     leaveDone_F47C  ; finished
F467 BD EC 80        jsr     selectRAMpageForFile_EC80 ; select in the relevant RAM page based on file number (byte_15D)
F46A A6 00           ldaa    0,x             ; get char for file
F46C BD EC 79        jsr     selectRAMPage0_EC79 ; select 32 KiB RAM page 0
F46F 08              inx
F470 DF 67           stx     word_67         ; update send pointer
F472 81 09           cmpa    #9              ; ascii < 9 translates to '?'
F474 2D 08           blt     translateUnusual_F47E
F476 85 80           bita    #$80            ; high ascii translates to '?'
F478 26 04           bne     translateUnusual_F47E
F47A             leaveValid_F47A:
F47A 0A              clv
F47B 39              rts
F47C             leaveDone_F47C:
F47C 0B              sev
F47D 39              rts
F47E             translateUnusual_F47E:
F47E 86 3F           ldaa    #'?'
F480 20 F8           bra     leaveValid_F47A
 This appears to be relatively straight-forward:  verify not out-of-bounds, then get a character at the current 'send' location @ word_67, translate any weird ones (I don't think this should happen normally), and return.  Overflow V is used to indicate failure (this is a common convention in these routines).
