Measurements
A project log for Water Meter Monitor with Raspberry Pi Pico W
Use a raspberry pi pico w and a magnetometer to keep an eye on water consumption, in real-time!
sciencedude1990sciencedude1990 02/21/2023 at 17:000 Comments
First, I took measurements with the LSM9DS0 taking measurements as quickly as it could.  That is, ~100 Hz.
Here is the water tap open a bit.
Here is the tap fully open.
The detection algorithm is pretty simple: Once you have a reading greater than 6050, look for a reading less than 2500.  Once you get less than 2500, look for a reading above 6050.  Once you get past 6050, increment a counter by 1, and start looking for <2500 again, and so on.  From each peak to peak (i.e., 1 count) is approximately 0.0657 L of water.  Pretty fine granularity!
