Hello, the problem was NOT a defect relay...ist was a defect solder point. I only had to heat it up. Now I mounted the modules together, the instruction register, the instruction decoder, the control unit state register and the control unit state decoder:
Now I will start with the uProgram for the NOP command (page 39) and the uCommand (page 20).
