Here you see the new module mounted on the complete control unit:
The open connections you see on top of the "bus module" will be filled with the state machine modules for the different CPU commands. The first one will be the NOP command.
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
